Discussion topic: wifi keeps dropping out
This message was authored by: Lino47435
wifi keeps dropping out , speed test is fine on my phone but keeps losing internet on my PC , one minute all is fine then it loses connection and nothing works
Re: wifi keeps dropping out
@Lino47435
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
If this is of no help give Sky a call to report it to them.
This message was authored by: texprez
I've been having the same problem. I only got Sky Broadband a few weeks ago and when I reported the problem I was advised that the router had not been set up correctly and they suggested changing the router WPA setting from WPA3 to WPA2. (Via the mysky app.) Since then I haven't had any drop outs. BUT I only had the conversation with Sky this morning so I can't be absolutely sure that this is a permanent fix.
@texprez Where you on full blown WPA3 or using the WPA3-T mode for the wireless securities? It make a difference....
I was on T. But when I just looked to check, because I couldn't remember exactly without looking at the setting again, the router is now showing as T again.  So I've no idea why it's reverted or if that undermines my suggested solution. I'm due a follow up callback from sky tomorrow so I can ask what they think.
@texprez Below is all the info about it etc, and how to change, but the default is WPA3-T with the sky Max hub and causes all kinds off stability with some wireless devices, that is why recommended to drop back to WPA2-PSK for wireless......
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
