Discussion topic: wifi issue with the checker
Message posted on 15 Oct 2024 08:14 PM - last edited: 15 Oct 2024 08:15 PM
online/app ? 🤔🙄😥 any advice and help will be very appeciated 🙂
Message posted on 16 Oct 2024 06:50 AM - last edited: 16 Oct 2024 07:48 AM
Re: wifi issue with the checker
If you click on the wifi tile, what does it suggest on the next screen?
Is your wifi working ok?
If so, maybe just a MySky glitch.
Perhaps, might be worth rebooting your router.
Message posted on 17 Oct 2024 09:11 PM - last edited: 17 Oct 2024 09:25 PM
@lettice it was showing that they werent getting any info from the router and so i left it a couple of days but the same day i contacted sky (15th oct 2024)and they said it sometimes says tht but i could tell they wasnt relly intrested 🙄and it corrected it self and went back to normal and had no need to reboot😁🙂but now it says where it should say sky q now sayss sky+but i havent had +since 2020🙄🤔
