Discussion topic: problem with wifi
Message posted on 13 Sep 2025 07:22 PM
problem with wifi
my wifi keeps on dropping out multiple times
Message posted on 13 Sep 2025 07:33 PM
Re: problem with wifi
@SLB2
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 13 Sep 2025 07:34 PM
@SLB2 Is it only on a specific device that you loose the wifi, see the link below if iy=t is the sku hub!.
