Discussion topic: Wifi
This message was authored by: Betridge12
Wifi
My Wi-Fi keeps disconnecting
Re: Wifi
@Betridge12
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
