Discussion topic: my network is failing
Message posted on 29 Sep 2025 12:56 AM
The videos keep freezing, it seems like the speed is not right with what I pay my internet is slow
Message posted on 29 Sep 2025 06:59 AM
Re: my network is failing
@Brenda18 most probably the issue is poor WiFi signal level around your home but check the servicecchecker in the My Sky app shich will show you the speed to your hub which is guranteed.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
