Discussion topic: my home security system no longer works as my broadband is now 5 ghz instead of the old 2.4ghz is th
This message was authored by: graham1721
what can i do about the above
Re: my home security system no longer works as my broadband is now 5 ghz instead of the old 2.4ghz i
@graham1721
Which hub do you have?
Avatar for graham1721
Level 0 icon
my home security system no longer works with my broad band update as it is now 5ghz and it used to be 2.4ghz is there anything i can do
Level 0 icon
sky superfast
@graham1721
Below are the instructions to seperate wifi for black routers if you have a white hub then go to the bottom of the page on how to temporarily disable 5ghz
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
