Discussion topic: issues using ethernet cable pc not picking details
Message posted on 13 Feb 2024 11:54 AM
Neither pc or laptop can detect settings required IP Address, Subnet Mask details and Default gateway details these can be entered manualy if I had those details
Message posted on 13 Feb 2024 12:02 PM - last edited: 13 Feb 2024 12:03 PM
Re: issues using ethernet cable pc not picking details
@Brian+Dill wrote:
IP Address: anything not already in use, in the format 192.168.0.x (where x is between 2 and 254)
Subnet Mask: 255.255.255.0
Default gateway: 192.168.0.1
Note however that if DHCP from the Hub isn't working then you've probably got other problems.
Message posted on 13 Feb 2024 12:11 PM
If its happening when connected via ethernet this suggests the cable isnt working or it isnt connecting properly.
Is the cable you are using fully gigabit compliant with all 4 pairs wired up as Sky hubs can be very picky.
