Discussion topic: is there a usb device I can plug into my laptop to get faster wifi connection please
This message was authored by Martin-N This message was authored by: Martin-N
Hi I am wonderng if there is a faster usb device for wifi that I can plug into a laptop to get faster connection than 6mb's? I am thinking by now there must be a faster device to connect to hub ?
Re: is there a usb device I can plug into my laptop to get faster wifi connection please
@Martin-N
Typically that's an ethernet cable ; )
If you really want 'better' WiFi then anything you plug in needs to be more recent hardware than that currently in use: what make and model of laptop is it?
Improving the signal reaching the laptop location may well be a better solution.
Martin-N
Hi Thanks for replyling its ok on ethernet just wifi is aweful even with repeater Its Aspire E15 , ES-571-323F
@Martin-N
OK: a quick look indicates that's a pretty old model (Windows 8 era) with 802.11b/g/n WiFi built-in.  This suggests that an 802.11ac USB WiFi dongle might be an improvement: perhaps something like the TP-Link ARCHER T2U PLUS AC600 Dual-Band Wireless High Gain USB Adapter.
Keep in mind that it's an old laptop though, and if it's still got a spinning hard drive in it will never feel speedy.
Hopefully it's not still running Windows 8?
Martin-N
Tanks for replying , not at all its pretty fast runs QGIS  and other demanding programs with Windows 22H2 if you mean by old no its dosnt have TPM I think so no Windows 11 like half of the country who cant get new processors  currently . Has 802.1n  Wifi if that helps . woould a dongle help?
Martin-N
Timmy Thanks have gone for adaper
