Discussion topic: internet keeps going off
Message posted on 13 Nov 2025 03:59 PM
working one minute going off the next for long periods and the middle button which should be green keeps flashing red
Message posted on 13 Nov 2025 04:05 PM
Re: internet keeps going off
@Anonymous
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
