Discussion topic: Broadband issues
This message was authored by: Lee310
Broadband issues
Broadband keeps cutting out on and off since somebody last looking at this 8th November
Re: Broadband issues
@Lee310
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
