2
This discussion topic has been answered Discussion topic: installing a 3rd party WIFI router
This message was authored by: Robert-Mac
Hi, I have added a TP-LINK wifi router to my system and switched off my SKY Hub Wi-Fi. Everything is working well, with the Sky Hub handling the internet connection and the TP-LINK handling the Wi-Fi connections.
However, I had the idea of having two wifi networks, so I thought I'd reactivate the Sku Hub's wifi. Unfortunately, I don't know how to reset the hub's Wi-Fi. According to the My Sky app, the hub's Wi-Fi is active, but it actually is not. Is there a way to physically reset the hub so that the wifi is reactivated?
This message was authored by: Doc5907 Answer
Re: installing a 3rd party WIFI router
@Robert-Mac
If you want to reset the White Sky Max Hub you should press and hold in the WPS button on the side for 30 secs until the led flashes and then release it when the front LED starts flashing green.
Sky Q 1TB UHD
LG TV
Sky Mobile
@Robert-Mac
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for Robert-Mac
Thanks for your help. It worked like a dream.😀
