Discussion topic: WiFi not working
This message was authored by: Johnboy751
WiFi not working
Internet light on hub not green
Re: WiFi not working
@Johnboy751
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
