Discussion topic: Internet not connected
Message posted on 21 May 2026 02:04 PM
Message posted on 21 May 2026 02:22 PM
Re: Internet not connected
@LouiseM93
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
