Discussion topic: iPad suddenly saying weak security on wifi
This message was authored by: stevey12
Hello
About 4 months ago we changed to Sky fibre, and recently I've upgraded my iPad, and occasionally my WiFi is saying ' weak security', I've never had this before ..
I've checked the security which says it is WPA2-PSK, should this not be WPA3 ? , and if so, how would I change it please, or would I need to call Sky?
Assuming it wouldn't be my iPad that's causing it, and needs updating to iOS 18.3 ?
Thank you
Re: iPad suddenly saying weak security on wifi
The white Max Hub supports WPA3 but no earlier model does.  With Max the security level is adjusted in the My Sky app.
Typically the warning generated by iThings is incorrect.
Avatar for stevey12
Thank you Timmy
We have the black box, not the white, so that makes sense
