Discussion topic: connecting to the router
Message posted on 15 Aug 2026 05:24 PM
Message posted on 15 Aug 2026 06:17 PM
Re: connecting to the router
@Shaahin wrote:
Please name them with two separate names if possible.
That isn't something Sky will do for you.
With a black Sky Broadband Hub it's a DIY process.
It's not possible on a white Max Hub or Gigafast+ Hub anyway.
Message posted on 15 Aug 2026 06:51 PM
My device model is Max Hub, what should I do?
Message posted on 15 Aug 2026 06:53 PM - last edited: 15 Aug 2026 06:54 PM
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to disable the 5Ghz WiFi band if you wish.
Unfortunately the 5Ghz and 2.4Ghz bands cannot be run independently.
Message posted on 15 Aug 2026 06:57 PM
I hope this works and fixes it.
Thank you
