This discussion topic has been answered Discussion topic: connecting Alexa device
Message posted on 21 May 2025 12:29 PM
I have recieved an upgraded router from Sky and i can not pair my TECKIN PLUGS for my Alexa to pick up
Message posted on 21 May 2025 09:11 PM
@Blaze1 If they do work then might have to try look into spliting the Wi-Fi frequencies to see if they can then be seen by the rotuer.
Message posted on 21 May 2025 12:34 PM
Re: connecting Alexa device
@Blaze1 Is this the new white router from Sky and you changed from the black router, which black router did you have before from the link below.
Message posted on 21 May 2025 12:37 PM
Hi no this was the same style black router aperantly the one i had is being switched off this year
Message posted on 21 May 2025 12:39 PM
@Blaze1 Did you have the Sky Q hub and been moved on to the Sky broadband hub?
Message posted on 21 May 2025 12:42 PM
Yes ive just relised by looking at the link you sent
Message posted on 21 May 2025 12:52 PM
Should give you a bit of background first of all im not too technically minded pension age, second this is a replacement router from the first upgrade , only lasted a few days and it was fitted by an engineer at my home
Message posted on 21 May 2025 08:50 PM
@Blaze1 Did you have a specific name for your Wi-Fi network on the last router or did you just leave it on the defaults? Does every other device see the Wi-Fi name and able to connect to the internet?
Message posted on 21 May 2025 08:55 PM
Left on default every other device picks up my router I'm going to try my teckin plugs at family home this weekend to confirm that they still work
Message posted on 26 Mar 2026 09:32 AM
I'm having exactly the same problem with my replacement router and Teckin plugs. Did you get the problem resolved if so what did you do.
im also not tech.
