Discussion topic: connect Smart devices
This message was authored by: Paul864
Message posted on 19 Jan 2026 11:53 AM
I need to connect Smart Devices to my WiFi, But i need to change from 5ghz to 2.4, and don't know how
Find out more
Message posted on 19 Jan 2026 03:24 PM
Re: connect Smart devices
@Paul864 what colour Sky hub do you have?
For the black hubs follow the instructions here Split Sky WiFi bands
For the white hubs go into the My Sky app and find the Hub's sdvanced settings page. Go on Disable WiFi and turn off the 5GHz band. Then oncecthevhub has restarted connectvyour devices. Then go bsck into thecsame pagecand switch thec5GHz back on. Your devices should stay connected..
