Discussion topic: Slow Broadband
This message was authored by: Manion56
Slow Broadband
I have a new installation. Despite rebooting and resetting it's still slow or drops out. Connected is TV, Tablets x2 and Phone. Ant clues or suggestions?
Re: Slow Broadband
@Manion56 while it could be the speed to the hub but more likely is poor WiFi spedds in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
