Discussion topic: broadband not working
This message was authored by: Joe170
My WiFi connection was slow and I received a message from open reach to inform me that they had detected an issue.
when I used the help guide it showed that the passive optical network” (PON) light is solid green and the “loss of service” (LOS) light is off, then it’s working properly.
The guide advised the following :This means you’ll need to contact the company you buy your broadband from as there may be a problem with their network.
On the WiFi box itself the internet and voice lights are orange.
Re: broadband not working
@Joe170
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
