Discussion topic: **bleep**e wifi once again
Message posted on 07 May 2025 09:43 PM
Can't even watch television! WiFi is dropping out can't play computer games this is a ongoing issues since I have been with sky
Message posted on 07 May 2025 10:18 PM
Re: **bleep**e wifi once again
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Message posted on 07 May 2025 10:36 PM
It's dropping all the time we've tried everything ! I'm closing my account and going with another provider tomorrow I'm sick to death of this paying for a service that is a load of **bleep**
Message posted on 07 May 2025 10:40 PM
What was the result of the line test ?
Message posted on 07 May 2025 10:51 PM
All tests are fine ! Bit we can't even watch telly without it sticking ! Can't play on gaming, I'm calling tomorrow to cancel I'm sick of it
Message posted on 08 May 2025 05:27 AM
@Kirstygrierson to stream TV you need a decent wifi signal. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
