Discussion topic: WiFi keeps dropping or is weak
Message posted on 04 May 2025 09:39 PM
Message posted on 05 May 2025 07:01 AM
Re: WiFi keeps dropping or is weak
@BlakeD poor wifi coverage is a common issue while adding boosters can help the boosters themselves need a strong signal to work which if your cameras are outside can be an issue. Best solution I have found is a whole home wifi solution in my case has 3 units one on esch level connected to a Sky hub whose WiFi is not used, these create a mesh wifi network.This gives coverage for external devices like Ring doorbell, EV charger etc. but whether that works depends on the layout of your home and how it is built.
Sky's version is called WiFi Max which can supplybupmto 3 extenders for whichyou pay extra each month.see https://www.sky.com/help/articles/sky-wifi-max
Message posted on 08 May 2025 06:28 AM
Message posted on 08 May 2025 07:22 AM
@BlakeD have you asked Sky to send out a pod extender or arrange for an engineer to check your network bith if which can come as part of the WiFi Max package?
