Discussion topic: Xbox connection poor and lagging
This message was authored by: LMP89
Message posted on 07 Aug 2025 09:51 AM
The connection to our upstairs Xbox is poor and ruins game play. The way our house is built the Xbox is almost directly above the box however as the bedrooms are an extention it sits on the otherside of what is effectively an external wall.
Message posted on 07 Aug 2025 10:37 AM
Re: Xbox connection poor and lagging
@LMP89 Looks like you are having wireless wi-fi signal issue, and for gaming Ethernet cable from the X-Box too your sky Hub will be the best way to sort it out! Otherwise you need to boost your wi-fi signal to the location that you need it in!
