Discussion topic: sky max pod
This message was authored by: laptop+for+disco
sky max pod
plugged my sky max pod in living room for remote connection to  sky max hub this morning but when pc is connected using a ethernet cable it flashes white and fails to connect to internet. pc does not use the wireless wifi only ethernet cable. pc work perfect on long ethernet cable but not on sky max pod.
Avatar for laptop+for+disco
Re: sky max pod
this pod even fails when in same room 1 metre away from sky max hub. needs resolved or cancelled
Re: sky max pod
@laptop+for+disco Was the pod working, you moved it and now it is not connected back to the Hub! Then you moved it all again back to the hub and it no longer connects again!
