2
This discussion topic has been answered Discussion topic: Xbox Interference
This message was authored by: CJ+Keen
Xbox Interference
Whenever I turn on my Xbox Series X, it knocks our Sky Q mini multiroom box off of the network. The mini box is saying there are connectivity issues. This has only been happening the last week or so. We have had the same Sky equipment for a couple of years, and the Xbox for nearly a year. Looking for advice please
Re: Xbox Interference
@CJ+Keen wifi conditions change due to multiple factors but the most common is interference from other networks. You can try powering down your hub and letting it reboot as it will then try tonfind the lesst congested wifi channel. If you want to be more scientific and have a windows laptop orcan Android phone download an app called wifi analyzer which shows all wifi networks within range with theircsignal strength and channel. A signal on the same or adajacent channel as your devices are using will interfere.
Wifi is always a poor choice for gaming so you msyvwant to look into using either ethernet cables or powerline adapters to connect your Xbox.
Avatar for CJ+Keen
@Chrisee
Just linked my Xbox with an ethernet cable and the problem seems solved.
Thanks for the assist!
