Discussion topic: Wifii issues
This message was authored by: Cath53
Wifii issues
My internet get flipping in and out of internet connection checked all wires etc reset everything and still doing it my router has no obstruction can anyone help please
Re: Wifii issues
@Cath53 You can either check it yourself or call CS 150 from your landline and have them check for you!
Try running the line test here to see if any faults are found:
