Discussion topic: Can’t connect the WiFi
This message was authored by: Dcarrer
All the lights in the router are green,  however the WiFi is not connecting.
Re: Can’t connect the WiFi
@Dcarrer Is it the wifi or the actual broadand as they are both different? You can just try a power off, leave five minutes and back on again to see if it clears any hub problems!
