Discussion topic: Wifi
This message was authored by: Wifi2025
Wifi
Why does my wifi go completely about 11 at night it cant even find my wifi code not great at all
Re: Wifi
@Wifi2025 unless your Sky hub is rebooting you should see the WiFi SSID at all times even if the connection isn't usable. Check the lights on your hub see https://www.sky.com/help/articles/hub-lights-explained-start
The only timers have to be set by the account holder. The only other explanation is something causing interference in your home.
