Discussion topic: Wifi
This message was authored by: McEwen
Wifi
Why is my WiFi not working but check says ok
Re: Wifi
@McEwen
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
