Discussion topic: No interne
Message posted on 12 Dec 2025 06:12 PM
No interne
Hi internet has 2 green lights and middle light is red
Message posted on 12 Dec 2025 06:45 PM
Re: No interne
@Barree4829
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
