Discussion topic: No wifi Manchester area
This message was authored by: Dominohoohoo
No Wifi box is red
Re: No wifi Manchester area
@Dominohoohoo it sounds like your broadband that is down rather than the. WiFi in your home.Run the serviceccheckker in the My Sky app using a mobile device as that will tell you if Sky arexaware of an issue affecting your line. If **bleep** arent call them and report the issue.
@Dominohoohoo
Your new thread asking the same has been removed. Your first post has been replied to.
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
