Discussion topic: Wifi
This message was authored by: Claire_2
Wifi
Wifi keeps cutting out
Avatar for Claire_2
Level 0 icon
Re: Wifi
WiFi keeps cutting and internet light on hub flashes the turns of so only 2 lights on not the normal 3
Re: Wifi
@Claire_2
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
▪️I AM NOT A SKY EMPLOYEE ▪️
