Discussion topic: Wifi
This message was authored by: Priv
Wifi
My wifi is not workint and has a orange light
Re: Wifi
@Priv See if the links below help you in any way!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
Avatar for Priv
Level 0 icon
Re: Wifi
The service checker is saying my service is but internet light off
Re: Wifi
@Priv  You may need to run it again later to see if it picks up a fault.
