Discussion topic: Wifi Signal Strength
This message was authored by: Fahad-1
Message posted on 29 Nov 2025 11:55 AM
Even with the new wifi max hub. Only 1 bar of signal upstairs where router is downstairs.
Find out more
Message posted on 29 Nov 2025 12:04 PM
Re: Wifi Signal Strength
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
