Discussion topic: Wifi
Message posted on 20 Oct 2025 09:43 AM
Wifi
The WiFi box keeps going off every couple of hours loosing connection. Iv had this issue before and someone came out to fix it and said issue was sorted. However it's been still happening.
I am not happy with this and if this continues I will leave sky
Message posted on 20 Oct 2025 10:05 AM
Re: Wifi
@Farzana2412
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
