Discussion topic: Briadband not working
This message was authored by: Terry1954
Tries tge sky help it went through all the testing and set up, it states your all fine. Unfortunately it's not
Re: Briadband not working
@Terry1954
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
