Discussion topic: WiFi
Message posted on 20 Oct 2025 08:47 AM
WiFi
Internet not available- have rebooted - lan light is flashing
please correct
Message posted on 20 Oct 2025 10:02 AM
Re: WiFi
@Rok17 wrote:
please correct
@Rok17
This is a customer ➡️ customer discussion forum where we try to help other Sky customers. You aren’t speaking to Sky staff by posting on here.
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
