Discussion topic: Wifi
Message posted on 12 Sep 2025 07:49 AM
Wifi
My WiFi is playing up. The green light on the front of the white box is flashing green any help would be appreciated
Message posted on 12 Sep 2025 07:53 AM
Re: Wifi
I've moved your post from the Sky Q board.
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
