Discussion topic: Mr Prince
This message was authored by: Princedanquah
Mr Prince
Good morning I got problems with my broadband
Re: Mr Prince
@Princedanquah
What problem?
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
