Discussion topic: Slow/no connection in other rooms
Message posted on 11 Sep 2025 09:47 PM
My broadband connection has been very poor recently. When moving slightly away from the room where my broadband hub is, the connection is almost non-existent. My SkyQ in the living room now gets no WiFi connection at all. This wasn't the case before and i would need someone to help urgently.
Message posted on 11 Sep 2025 09:56 PM
Re: Slow/no connection in other rooms
@Kai9 Was there anything that has changed before you started to get this!
Message posted on 11 Sep 2025 10:02 PM
Not that I know of.
Message posted on 11 Sep 2025 10:06 PM
@Kai9 Sky Broadband Hub, and the Sky Q both act as a wi-fi transmission point, nothing has moved, you did not do an upgrade to Fibre etc!
Message posted on 11 Sep 2025 10:27 PM
Then what is the problem I have now? I'm no longer able to use WiFi in other rooms in my house.
Message posted on 12 Sep 2025 07:50 AM
@Kai9 When you post on the Forum you are not talking direct to sky, just customers like yourself trying to help you. What specific hub do you have from sky see the link below and also any booster's if using. As you say that nothing has changed since the fault has developed, have you switched the sky hub off for five minutes and when it goes back on do you have the same problem with the lack off signal strength that you are seeing!
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
