Discussion topic: Wifi
Message posted on 08 Sep 2025 02:39 PM
Wifi
Hi the WiFikeeps going in and out
Message posted on 08 Sep 2025 02:48 PM
Re: Wifi
@James4410
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
