This discussion topic has been answered Discussion topic: Internet connection
Message posted on 08 Sep 2025 02:20 PM
My internet connection doesn't work. The light is off. What can I do? I need internet to work
Message posted on 08 Sep 2025 02:27 PM
@Vlangianese
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@Vlangianese
Message posted on 08 Sep 2025 02:55 PM
Re: Internet connection
Hi, thank you for your message , I friend all the suggestions, but nothing , my internet connection doesn't work. I got two green lights the "power" light and the WiFi, internet is switched off. I need help.
Message posted on 08 Sep 2025 02:58 PM
Included in my first post was this section…
