Discussion topic: WiFi not working
This message was authored by: AlisonNash
WiFi not working
Hi my WiFi seems to have gone down and there is a red light on the box above what says voice
Re: WiFi not working
@AlisonNash
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
