Discussion topic: Wifi
This message was authored by: Anthoney
Wifi
Hi, my wifi keeps dropping on average every half hour, only within the times of 11.00am to 17.00.
I work from home and the is affecting my employment.
I do run the the SKY wifi check, this is no help as it always states that connection is good and working. Which at times is incorrect. The orange light is mostly on.
Re: Wifi
@Anthoney  Black or white router from Sky?
Avatar for Anthoney
Re: Wifi
Hi
It's a black router.
Re: Wifi
@Anthoney Could you please post your router stats following the link below.
