Discussion topic: Wifi security
This message was authored by: SA191
Wifi security
My WiFi says weak security on my iPhone. What does this mean and how do I resolve it?
Re: Wifi security
@SA191
This is an Apple issue so you will need to change the setting on your broadband router as per this information from them:
https://support.apple.com/en-gb/HT202068
To do this you will need to login to your hub and change the security setting:
https://www.sky.com/help/articles/access-your-sky-broadband-hub-settings
Re: Wifi security
@SA191
Note that WPA2-PSK is the highest encryption level available on any of the black Sky Hub models.  The white Max Hub and the new Gigafast+ Hub support WPA3.
