Discussion topic: Help I can't connect
Message posted on 04 Oct 2025 01:18 PM
Message posted on 04 Oct 2025 01:25 PM
Re: Help I can't connect
What are the lights showing on your hub, are they all green or are some flashing as this explains the lights on the hubs:
Try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 04 Oct 2025 03:12 PM
@MissSLG Did you home move at the time via sky, and your account may have some info, and if not you should be calling to find out what is going on!
