Discussion topic: Wifi problem
Message posted on 19 Jun 2025 02:52 PM
Wifi problem
Message posted on 19 Jun 2025 03:00 PM
Re: Wifi problem
The below link explains the lights on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
Message posted on 19 Jun 2025 04:08 PM
Re: Wifi problem
I have this also. I rely on WiFi because mobile signal is not good here. Don't know if this will post
Message posted on 19 Jun 2025 04:36 PM
Re: Wifi problem
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 19 Jun 2025 04:43 PM
Re: Wifi problem
Apparently there is an exchange problem in my area. The service checker said there was a problem but provided no further info. I kept going round in circles with the online stuff but eventually spoke to someone at sky who told me open reach are working on it apparently. This is the second outage in 2 months, not exactly a stable service.
Message posted on 19 Jun 2025 04:52 PM
Re: Wifi problem
@Carl0974 There is no such thing as a 100% guaranteed Broadband service!
Message posted on 19 Jun 2025 04:56 PM
Re: Wifi problem
Yep Jim, I am very aware of that☹️
Message posted on 19 Jun 2025 05:03 PM
Re: Wifi problem
@Carl0974 It is always difficult when you rely on wireless wi-fi connected fixed landline Broadband in a poor signal area for mobile, know exactly how you feel, have to go about half a mile to get a reasonable mobile signal so not able to tether when issue!
Message posted on 19 Jun 2025 06:01 PM
Re: Wifi problem
Have had a text stating the issue in my area has been fixed however still no BB connection. Have restarted and gone through everything but no joy. Now waiting for an engineer to look at an 'external problem'. Sometime between 2 and 5 days.
Message posted on 19 Jun 2025 06:22 PM
Re: Wifi problem
@Carl0974 That's the problem, don't know what you have, how you are connected, so just now way to advise, Off and On but leaving the hub for a good hour is the normal and see if the hub connect;s and maybe also paths through a different route, but with Exchange issue's if you cannot get past or connected to it you are not going anywhere quickly.
So you just leave the hub on and when it connect's and picks up you are good to go!
