3
This discussion topic has been answered Discussion topic: Broadband outage again
This message was authored by: FERR19T
I'm not technically minded but why do I have to suffer a broadband outage again in York.
At least it reminds me of the benefit of sky Q.
Move to sky stream ? Not a cat in hell's chance.
Re: Broadband outage again
@FERR19T
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
@FERR19T
Avatar for FERR19T
Thank you for the reply and advice.
I did the service checker and there was a broadband outage. Annoyingly no info from sky when outage happened or corrected.
Thank goodness for sky Q, I still was able to watch tv.
@FERR19T And that is the beauty off having a seperate system so it all does not go pear shaped at the one time!
