Discussion topic: Wifi playing up on mobile
Message posted on 18 Nov 2024 06:17 AM
Message posted on 18 Nov 2024 07:23 AM
Re: Wifi playing up on mobile
@Morgami are your other devices working properly? If not then there is an isue with your broadband which needs checking out if thry are tge issue will be with thst phone. Check its network settings for the Sky WiFi connection are set corectly and the phone is getting an IP address from the Sky hub in the range 192.168.0.2 to 192.168.0.254.
Message posted on 18 Nov 2024 07:28 AM
Hey,
I've been getting this problem last few days as well no WiFi on mobile or tablets. However mine even if you switch the mobile data on the home WiFi is still not connecting. Just keeps saying turning on and then blank.
The Internet is working on the sky glass.
Message posted on 18 Nov 2024 08:25 AM
Mine loads but is awful! The speed tests are non existent. I hope someone can help.
Message posted on 19 Nov 2024 06:49 AM
Something must be wrong at Sky's end.
Mine started working OK late yesterday.
