Discussion topic: Wifi not working
This message was authored by: Peter456
Wifi not working
WiFi not working, sky Q and mobile devices cannot use broadband. We've not had internet or WiFi access since 4th April 2026.
Re: Wifi not working
@Peter456
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
