Discussion topic: Wifi not working
This message was authored by: MJSTO
Wifi not working
WiFi poor for a few days, now not working at all - Dorset area. Checks are coming back fine but it's like the hub is not connected at all even though all lights are fine.
Re: Wifi not working
@MJSTO Is the wireless connection showing bars with the ! exclamation mark, wireless connected but no internet symbol on all your devices?
Avatar for MJSTO
Yes, it says 'no internet connection' while being connected to the hub.
This message was authored by: Hungrydog
I'm a new customer connected today and exactly the same thing is happening. It shows all three bars on the menu and the sky test says everything is connected but my browser says I am not connected to the Internet. It keeps dropping out. If it carries on like this, I'm going to go back to using my phone as a hotspot and get rid of sky
@MJSTO Have you tried to run the test linked below when you have that condition?
Try running the line test here to see if any faults are found:
@Hungrydog You may be slightly different as new today, sky have up until midnight to sort out the connection to your line!
Avatar for MJSTO
Yep, still broken. I will ring them In the morning. I think it's an FTTC issue perhaps?
@MJSTO You may wish to try powering off the sky Hub, but it will need to be off for more than 1 hour to get a new IP, you can run a www.whatismyipaddress.com before and after to see that it changes values!
Avatar for MJSTO
Hi all. An open reach engineer is going to look at the FTTC as suspected.
